Question 144hz monitor
Mar 17, 2019
Hello everybody,
would like to buy a 144hz monitor (Viewsonic XG2402 or Benq Zowie XL2411P)
my computer...
GTX 1050 2gb
AMD A10
8 GB di RAM
1tb hard drive
will this system support a 144hz display?
thank you
To answer your question, yes this system will run 144hz with no problems.
Between the two monitors it is pretty much identical, Zowie is definately far more renown than Viewsonic in terms of the E-Sports business. It depends what is within your budget, personally I would go with the viewsonic as it does everything the Zowie offers but with more peripherals to go with it (e.g the integrated headphone stand). If that is no concern to you then go with the Zowie as it is slightly cheaper in that regard.
