[SOLVED] 14700K is fine at 5.6ghz under no load, but once i stress test it, it drops to 5ghz or even less ?
26
Hi guys, I tried everything. CPU temps don't go above 60C but as soon as I try to stress test it, the frequency drops sometimes even below 5ghz. My XTU score is only 9k where other people at 5.6ghz with AIO cooler like me reach around 13k. It must be something with the voltage or a blockage that doesnt let the CPU actually try for stable 5.6ghz. I dont want overclocking, i only want the advertised speeds I paid for.
Specs:
PSU: Gigabyte 850w Gold UD
Mobo: Gigabyte B760M D3HP Rev 1.0
CPU Cooler: MSI Water Cooler AIO 240
BIOS is updated to latest version. Any questions or further details please don't hesitate to ask.
Reactions: jnjnilson6
Msi Water cooler AIO 240
MSI is the brand of the cooler while 240mm is the size of the radiator. MSI have had a number of trash AIO's...what model is the one you own? How is the AIO mounted in your case?
Bios is updated to latest version.
For the sake of relevance, it's best you mention the BIOS version instead of stating it's the latest.
Make and model of your case?
Temps dont go above 60C but as soon as i try to stress test CPU the frequency drops sometimes even below 5ghz.
How are you monitoring temps? What sort of benchmarking app's are you taxing the system with?
The B760 motherboards do not support an all core overclock like the Z790 motherboards support. As the load goes up, the MHz will go down.
What are the PL1 and PL2 turbo power limits set to? Use HWiNFO to confirm these settings. At default values the CPU will power limit throttle during any full load stress test. You can try increasing these limits. If the voltage regulators are not well cooled, you might end up with some VR thermal or VR current limit throttling.
B760 motherboards are not the best choice to get maximum performance out of a 14700K.
HWiNFO should also be able to report what the default turbo ratios are based on how many cores are active.
I am aware that the b760 is not the best option, however i only want the speeds i paid for, as i dont plan to overclock an already super fast CPU so i thought the b760 would be just enough. Those options in the BIOS are all set to AUTO. I will take pictures with my phone and hopefully once you see them you can tell me what to mess with cause there are like a billion options and i dont want to mess with them without knowing
Here is what HWinfo states:
View: https://imgur.com/LxTelqr
Here are my bios pics (forum wont let me post them here)
View: https://imgur.com/6WXB
View: https://imgur.com/r4wPzDsaM7
View: https://imgur.com/UUIs1iW
View: https://imgur.com/h10TmEe
View: https://imgur.com/Dxep3aD
MSI MAG CORELIQUID A13 240
AIO is mounted at the top of the case with the fans drawing in air from within the case
Bios version F7a
Case is 1st player Miku midi tower
I am monitoring temps using intel XTU and Hardware Monitor. I used XTU benchmark with score of only 9k while others with the same cpu get 13k. Also Cinebench
Post this HWiNFO data.
The 56 multiplier is likely only used when a single core is active. When more cores are active, the maximum multiplier is designed by Intel to drop. You can only bypass this limitation if you buy a motherboard with the Z790 chipset. Motherboards with the B760 chipset do not support this feature. Setting all cores to run at 5.6 GHz when all cores are active is considered to be overclocking.
If the turbo power limits are set to default values in the BIOS, the CPU will not be able to maintain full speed when it is fully loaded. You did not buy a 5.6 GHz CPU. You actually bought a 125 Watt CPU. You usually need to increase the turbo power limits to go beyond that. The motherboard voltage regulators should be able to handle more than 125W. They might not be able to handle way more than that long term. A 14700K needs way more than 125W to run at full speed indefinitely. Probably closer to 250W when running a full load application like Cinebench.
Those other users were likely using a Z series motherboard and they likely increased the turbo power limits significantly. Some motherboards automatically increase the turbo power limits without any user intervention. B760 motherboards tend to set the turbo power limits to the Intel default values.
My apologies. Here is the info
View: https://imgur.com/A1gG89M
Your screenshot shows the turbo power limits have been increased to 375W so that is OK.
The max multiplier when all 8 P cores are active is 55. The E core max is 43.
When running Cinebench, open HWiNFO and watch the Limit Reasons data. That will tell you the reason why the CPU is not running at full speed.
Edit - Your motherboard has set IccMax to 160.0 A. That might not be enough. Watch for some EDP throttling.
View: https://i.imgur.com/GugJR7D.png
Reactions: Phaaze88
Here are my reasons after running cinebench
View: https://imgur.com/Lddxypc
This is indeed true. XTU also stated that there is EDP throttling. I have no idea what settings to change. It also stated power limit throttling
View: https://imgur.com/HeXtDu3
View: https://imgur.com/PaJ63px
More info about ICC
On B760 motherboards using the latest BIOS versions, you cannot change IccMax while you are in Windows. Have a look in the BIOS. Maybe you can increase IccMax there. I recommend increasing IccMax for both the CPU and the Intel GPU. Current limit throttling will likely occur when the IccMax current limit is set to its default value.
The early motherboards and BIOS versions used microcode 0x104. This allows CPU voltage and IccMax adjustments while in Windows. Any version after that version does not.
Some motherboards have an option in the BIOS so you can switch to the older microcode version. I know that many Asus B760 and B660 motherboards have this option. Some Gigabyte motherboards might have this option too.
Too cheap of a motherboard I think that is most of the problem. Can't deliver the power.
Reactions: thestryker
Thanks for your reply, but im sure VRM's work in the sense that they regulate the voltage and current. Stability is not the issue, its the fact that I cant get to edit ICCMAX anywhere for some reason. Cant find it in the mobo settings anywhere
@Zerk2012 is right on the money.
You bought a motherboard that literally cannot deliver enough power to the CPU and that is the problem here. There's going to be 4 power stages of likely 50A (maybe 60A, but I doubt it) and the CPU under full load is likely pulling somewhere between 190-220A (this will depend on CPU quality). I'm taking a guess here that the IccMax limit is hard coded in the BIOS.
Would the ds3h rev 1.0 be enough since it has 6+1+1 vrm stages?
Maybe, but you're still cutting corners badly. For any of the 253W parts I wouldn't really advise going below 8. Power delivery just isn't something you can cut corners with on high power parts (this goes for AMD as well) and expect a good experience.
The pc only costed me around 1k euros and its selling price goes for like 2k in my country. Its true i missclicked on the motherboard as i wanted the ds3h version and accidentally missclicked the one i got today. If im gonna do this right i think im gonna go with the asrock steel legend b760m that has two ports for CPU power instead of one and has 12+1+1 for 50 euros more and try to sell my current one as much as i can milk it for. Let me know if this is an appropriate thinking option cause i wanna be done with it even tho in real life scenarios the throttling isnt delaying anything in my day to day use
You do realize that all responses you got until now have all been for overclocking your CPU right?!
In fact your CPU is already overclocked now and all responses are to overclock it even more.
Your CPU limit should be at 253 at max and it's at 375 that's 50% higher than it should be...a 50% "overclock" on the power.
What are the stock clocks then? What frequency is for 253?
