I put new life in an older hand me down HP Pavilion Elite m9040n by switching from the integrated GPU of Intel Core 2 Quad Q6600 to discrete AMD Radeon HD 7750. I chose the 7750 because it was cheap, had minimum oomph, didn't need additional power connectors, and would probably not overdraw on the 300W PSU. I also bought a UPS (saved me twice in the last 6 months). The UPS display says PSU is only drawing 120 W as I type this. I can get to 180 W if I play 3D game like Borderlands @ 1920x1200. I can artificially stress it with benchmarks up to 220 W, but that's the limit.
Minimum oomph is far from happy oomph. Seems to me that I could replace the 7750 with something much beefier. If the 7750's TDP of 75W leaves about 120W untouched, is there any reason I shouldn't get a better card as long as the TDP is under 195W (75W + 120W)? I know this assumes I'm not going to put anything else in there like more memory, or plug in another USB device, or ... anything. I also know that power from the wall does not equal motherboard power, does not equal TDP. I'm depending on it. If I'm drawing 300W from wall, I shouldn't be maxing out a no name 300W PSU that probably would not even get an 80+ rating.
I'm no noob, but I'm far from expert. I'm more noob++, you know, the classic "knows enough to be dangerous". Thanks for the sanity check. And a double thanks if you stop me from doing something stupid.
