A few years ago, i wanted to upgrade just my CPU, but instead i waited until now when i can do a entirely new build .
I'm looking to get some feedback on my component choices and to ensure there are no compatibility issues.
Here's what I've put together. The only components I'm sure about are the GPU and CPU. I understand that AMD GPU's provides excellent value for money, but I'm willing to pay more for lower performance in exchange for peace of mind when it comes to Drivers and troubleshooting.
I don't play many modern AAA games, and when I do, I don't mind reducing the settings, so I opted for the "ASUS TUF" 4070 TI Super that appears to strike a good balance.
It has a decent build quality, low noise and 2 HDMI Slots.
https://de.pcpartpicker.com/list/x7pPbL
The Case, PSU and Cooler are just picked for good reviews. Didn't look deep into those.
I wouldn't mind changing them based on your recommendations.
I'm unsure if my chosen RAM will have sufficient clearance with the CPU Coolers as PC Part Picker doesn't check certain physical constraints.
Thanks for reading and i look forward to your input!
Approximate Purchase Date: Next Month
Budget Range: 2000€- 2500€ including Shipping
System Usage from Most to Least Important: Gaming. Few AAA Games Like the Witcher 3 or Cyberpunk2077 or the upcoming S.T.A.L.K.E.R 2, but mainly for Competetive Shooters like CSGO, CS2 and Valorant.
Are you buying a monitor: Yes. Two.
Parts to Upgrade: Everything. New Build.
I might re-use my SSD that currently has my Operating system running to run the Operating system on the new build. Only if its possible to completely wipe it, otherwise i would just buy a new, small SSD for it.
Current SSD that has my OS on it:
https://www.amazon.com/SanDisk-240GB-Solid-State-SDSSDA-240G-G26/dp/B01F9G43WU?th=1
For everything else, i want a fast and big SSD like the one in the List as im currently using an ancient Harddrive with little space. I always have to delete stuff if i feel like playing another game for a while and i want to never have to deal with that again.
Do you need to buy OS: Yes. Preferably Win10 - Win11 comes with lots of Bloatware and im used to Win10
Preferred Website(s) for Parts: None
Parts Preferences: None except Nvidia for the GPU
Overclocking: No
SLI or Crossfire: I don't know
Your Monitor Resolution:1920x1080 or 1920x1200. Honestly, Monitors are way too in depth for me.
There are 20 different recommendations for whats best in Comp Shooters.
First Monitor should have the lowest Response Time possible and be around 240hz.
Second Monitor should have the same measurements and Appearance as the first one (if possible)
and i guess be 100+ hz.
Additional Comments: I prefer Air Cooling over Watercooling . No RGB needed. Running the usual Software/Launchers that comes with everything today. Nothing specific. If a game requires it, i use it. Of note might be Corsairs ICU and Razer Software, but that is subject to change, as i might look into buying a new mouse after the Update.
And Most Importantly, Why Are You Upgrading: My 1060 6GB and i5 6600k struggle too much. It takes way too much effort to get modern games to run, with some being almost impossible. (30-40 fps in Cyberpunk) Also, the difference in 60hz and 240hz is too big to not do. Played on a friends 240hz Monitor and it was a different game. Also, i just want a completely fresh System. There is propably loads of trash on my current system as i've been using it for 15 years.
Overclocking: No
