[SOLVED] 24-inch VS 27-inch
nahyan_121
74
currently i have 24 inch for years and soon am going to upgrade to 27-inch but i questioned my self and what i feel like that 27 inch is gonna make it worse for gaming cuz its bigger screen and it would be harder for my awareness and see the whole screen and spot things faster and with 24 inch its smaller you can see the whole screen and be aware of everything . what i wanna know is playing in 27 inch bad ? for anyone who has one i want your opinion
Depends on resolution and seating distance.
27" is a very popular size for 1440p monitors, arguably the best.
Sure there is more screen to watch, but everything going on is also proportionally larger, if you sat the same distance away from a 24" and 27" it may seem overwhelming at first. But, that is more likely than not either temporary or a seating distance issue.
nahyan_121
74
do you play on 27 inch ? or 24 and what do you think is the best
nahyan_121
74
I’ve used 27” at 1080p and 1440p. I much prefer 1440p but it requires a much better gpu. My current monitor is 27” 1440p 144Hz, I’d never go back to a smaller screen or lower resolution.
my plan is i will get a benq zowie xl2546s 1080p 240hz 1ms really good one and i will wait for companies to drop 1440p 240hz i know there is like 2 on the market out but really bad reviews on them like samsung g7
Unless your main priority is esports games I don’t see the need for going with 240 over 144Hz. 240Hz at the moment also always compromises colours and viewing angles.
