Hello everyone!
I recently get my self GTX1080 Armor OC from MSI and im experiencing twice as low FPS than i see in lots of differend benchmarks on youtube or benchmark sites.
My iron: View: https://imgur.com/a/wp7s5BQ
-i7 4790k (Turbo Boost on all cores ON, 4.5GHz)
-GTX1080 MSI Armor OC (1905MHz when fully loaded, 5005MHz memory clock)
-HyperX Savage 16GB 1600Mhz (2x 4GB 1600MHz, 1x 8GB 1866MHz locked at 1600MHz)
-MSI Z97S SLI Krait Edition MBO
-Fortron HyperM 500W PSU
-Kraken X41
-SSHD WD2 Black [120GB ssd (Windows only on SSD part of SSHD), 1T HDD (games and programs only on HDD part of SSHD)]
-Acer GN246HL (1080p, 144HZ)
Ive tried GTA V, R6: Siege, The Division 2, AC: Unity, PUBG and in all of these games i set settings exacly like in benchmark videos but never got close to results that are in videos. For example, GTA V, multiple people had 114-120FPS on ultra with exacly same HW as i have, but i got 2x as bad FPS, exacly my FPS is around 54-62 with exacly same settings like in videos. Same goes for The Division 2 where i saw in benchmarks, that people have 85-100FPS on ultra preset when again, i have twice as low FPS hovering around 70FPS, but dropping to 50-60 when outdors in highly occupied locations. In R6: Siege im experiencing better results where i have 100-120FPS on Ultra, BUT, in benchmarks i saw people having 190-220FPS on Ultra, and i will not go into detail with PUBG where i have 60-70 fps on Ultra with alot stutter. Keep in mind that i always set exacly same settings as people in benchmarks.
My CPU is mostly running at 60-80% usage, depend on games CPU utilization (60°C max. when 90% load). My GPU is mostly running at 90-98% usage, depend on games GPU utilization (73°C max. when 98-100% load).
I have just recently fresh installed Windows 10 with everything set to MAX. performance. All drivers updated through Driver Booster and GPU drivers with DDU. RAM is running at 1600Mhz with 1x dual channel and 1x single channel (2x4GB, 1x8GB). Everything 1080p.
So my question is. What can be causing this low FPS on such a HW?
-Kraken X41
