Question 3 Pin RGB Controller?
May 15, 2020
4
Hey everyone,
I'm not very technically savvy so I may use rubbish terms to describe things...
I got myself a new build the other day and have realised that my motherboard doesn't seem to have anything that'll help me control the RGB fans. I looked at what cable I had and I seem to have an 3 pin ARGB header(?) that could maybe be plugged in somewhere? ( Pic - View: https://imgur.com/a/s32b0rK
There doesn't seem to be anywhere on the motherboard however, can anyone recommend a decent and not so pricey controller that I can just plug in at all?
I appreciate the help!
The case should of came with a controller that you can use the reset switch on the case to change the RGB does it have any power connector for it?
LED Controller IncludedYes
LED Button - Easily control your fans and have access to several colour modes at the touch of a button, once connected your reset switch can be used to switch between the different colour modes.
https://www.cclonline.com/product/3...ase-with-Tempered-Glass-4x-ARGB-Fans/CAS3929/
Hey yeah, I read about that but I'm not overly keen on taking out and replacing stuff - I'd rather just get something I can just plug in... if that exists haha
