300W power supply what can I run?
shehan360
19
I got a EVER POWER 300W PSU
Here are the specs - 3.3V @ 21amps
5 V @ 15amps
12 v @ 11amps (first)
12 V @ 8amps (second)
here is my rig - Core 2 Quad Q8200 2.33GHZ
Intel DG31PR mobo
2 GB DDR 2 SDRAM
500GB SATA HArd
Samsing DVD Writer
Ok here is my problem can I run a Radeon 4850 on my rig?
AS you can see here in the reviews
http://www.techspot.com/review/103-asus-radeon-4850/page10.html
http://techreport.com/articles.x/14967/10
Those guys got way way way better rigs than me...
and the total Power consumption is around 245W max....??????????????????? :pt1cable:
The slower, DDR2 version of the HD4650 is five tiers higher than the 9400GT you have now; the DDR3 version is three tiers higher than that, and really doesn't cost any more. If you are determined to spend $100, buy the HD4650 for $50 and a more capable PSU that will support future upgrades for another $40-$50 (there will be an Earthwatts in this range, usually the 380, sometimes the 430; either will support a HD5750). Then save your money for better. Kludging together multiple PSUs is penny-wise and pound-foolish at best. The odds of killing your system and ending up with NOTHING should discourage you. Experiments like that are for when you can afford the worst-case scenario, and right now that does not seem to be the case.
shehan360
19
I currently have a 9400GT 1Gb ...suX...Dual power be more better option to me....I am going for something at 100 bux....4850 is 100 bux..Do you guys know whether there is Nvidia equal-vent to the 4850 or 4770? At that price of course..I am very much interested in the 3D vision thing..
sabot00
2,387
shehan360
19
Damn that aint cool.... 1 more question will it be a problem if the secondary PSU started before my primary one?
Note: I am using the secondary one to power the DVD, HDD and the 4850 or 4700
sabot00
2,387
Since 3D vision broadcasts 1 frame to each eye while shuttering the other it means a 60Hz monitor will only get you 30FPS MAX.
If you don't want eyesight then yes you can use any monitor.
I believe the cutoff line for "eyesight" is 100Hz.
