[SOLVED] 3060ti founders whine/ high pitch noise
I don't hear coil whine. I am not sure I hear anything out of the ordinary. IF it is indeed something weird, I would check the fans if they spin freely but only when the pc is powered down and you have properly grounded yourself.
check for obstacles/debris or anything that might interfere with the fans.
It was kind of hard to hear anything over the whooshing of the fans.
Is there a hybrid cooler in this PC?
Coil whine:
1)Is not a bad thing. It's just a nuisance, and nothing more.
2)Is caused by the electrical wiring inside the gpu being a little more sensitive to the power delivered from the psu than normal.
It doesn't hurt to ask Nvidia if they will replace it.
