Question 3080 ti only using 210w, with afterburner monitoring thinking this is 100% of the power limit
Bullszeye
36
12900k -(using only 85w at time of issue 10% cpu usage)
Z690 gaming wifi
32 gb 6000 mhz ddr5
980 pro 1 tb
860 evo 500 gb
kingston 1 TB ssd
WD 4 TB hdd
Gigabyte RTX 3080 Ti Eagle
Furmark score
What could cause this issue? I don't know when it appeared as I turned on cyberpunk today after a few months and I noticed i'm getting only 60 fps at 2k, then i saw the wattage at 210w. I checked windows power plan settings, turned off all power saving in bios, tried switching the PCI-e cables, nothing seems to work... I'm out of ideas...
EDIT: Score after clean install of latest nvidia drivers
36
What psu do you have there?
Maybe is a problem with newer drivers.. try with an older one
