No it doesn't but i got sata connection cables,iam taking about the power calculation,will this power supply be able to make it?Does the power supply have 2x PCIe 6 pin connectors (or 1x 6 and 1x 8 or 2x 8)?
Every GTX 970 has at least 2x 6 pins (mine has 1x 6 and 1x 8). Without the proper connectors the other details won't matter at all.
Do not hook up a video card this way either get a new PSU or don't put the card in.No it doesn't but i got sata connection cables,iam taking about the power calculation,will this power supply be able to make it?
Find full model name of the PSU.No it doesn't but i got sata connection cables,iam taking about the power calculation,will this power supply be able to make it?
I smell smoke.No it doesn't but i got sata connection cables,iam taking about the power calculation,will this power supply be able to make it?
I smell a house fire.Is hec raptor 500w will be good for the graphic card?
hp 800g1,What graphic card can it handle?
Well that's a SFF PC and the video cards available for it were all under 75W and SFF format. I believe the fastest thing you could get for this would be the GTX 1650, but it would probably also be relatively expensive. A 1050 Ti 4GB would also be an option.
In a post where someone's exclusively asking about old equipment suggesting cards that cost hundreds to thousands is completely worthless.The A2000 is basically a low power RTX 3050, that fits in a low profile case. It's pricey, especially in the 12gb configuration, but it's one of the fastest low profile cards you can buy. There's also the RTX 4000 SFF, with slightly more CUDA cores than a RTX 4070, and 20gb of VRAM, which is even more money, and more powerful.
What about 1060 3g do u recommend it?Well that's a SFF PC and the video cards available for it were all under 75W and SFF format. I believe the fastest thing you could get for this would be the GTX 1650, but it would probably also be relatively expensive. A 1050 Ti 4GB would also be an option.
What
No, it requires a power connector and I'm not sure there was ever a low profile 1060 periodWhat about 1060 3g do u recommend it?
Gtx 1650 super as a low profile card,is a good option?Well that's a SFF PC and the video cards available for it were all under 75W and SFF format. I believe the fastest thing you could get for this would be the GTX 1650, but it would probably also be relatively expensive. A 1050 Ti 4GB would also be an option.
only the regular GTX 1650 will work as the Super requires a 6 pin power connector.Gtx 1650 super as a low profile card,is a good option?
Will it work?
With a core i5-4570only the regular GTX 1650 will work as the Super requires a 6 pin power connector.
With the regular GTX 1650 that should be totally fine.With a core i5-4570
320w will work?
