I recently built a machine using a 3600x with the stock Wraith Spire cooler. I ran some tests to make sure my temps are ok, but I'm getting over 100 degrees in less than 10 minutes in a Prime 95 Blend test. It sits around 82 degrees until about 7 minutes in and then the temperatures skyrocket. I also ran AIDA64 Extreme for 10 minutes, but temps stayed in the 80s.
My question is, are these normal temps for the 3600x with the stock cooler? I understand this cooler has limitations, but I only expected thermal problems with overclocking.
Do I need to reapply thermal paste and reseat the cooler? Or is this normal?
System Specs:
CPU - 3600x stock cooler, no overclock
Motherboard - Asus Prime X570-P
RAM - G.SKILL TridentZ RGB series 16GB (2x8GB) 3200
GPU - Gigabyte GeForce RTX 2090 Super GAMING OC 3X 8G
m.2 SSD - WD Blue NAND 1TB Internal SSD
Case - Thermaltake Level 20MT ARGB
PSU - Cooler Master MWE Gold 750W 80 PLUS Gold
System Specs:
