Hi ! I'm running 3770k with everything at stock on BIOS except XMP profile, CM 212 Evo, 2 1000RPM 140MM fans in the case (fractal design r4), and arctic silver 5
recently i did run Prime95 and did reach 65degrees and then slowly going up to 70, CPU-Z says the core runs at 3.9GHz, are these temps a bit high?
