4790k Heat Issue - Low Idle first boot, high idle after enabling, then disabling turbo still high idle.
Rhinodtr
8
Hello all, i have just replaced my I5 4670k with my new I7 4790k. I'm using a H100i as the cooler. The first boot went fine, low idle temps in mid to high twenties so i then decided to try out the automatic turbo mode to bump it up to 4.4. I did this and had mid 40's as my idle and didn't enjoy seeing it his 70C only at the DayZ Main screen. So i rebooted the computer, set the Cores back down to 4.0 manually, and the idle temps are still sitting in the mid fourties. I'm not sure what is wrong or what might still be enabled which could be causing this issue. Thank you in advance.
CPU : I7 4790k @4.0
CPU Cooler : H100i
MB : Sabretooth Z97 w/ Thermal Armor
GPU: EVGA SC w/ ACX Cooling 770 @ 2gb
