I have an IN9-32X max MB and am using 2GB of OCZ2T8002GK memory. I upgraded to 4GB of G.Skill f2-8000CL5D-4GBPQ DDRII2GB. When running both sticks, I get the BSOD. When I run each stick individually, they run fine. Running both sticks together on memtest 3.4, I get hundreds of memory failures. When running memtest on one stick of memory installed, I get no memory failures.
This is the second set of memory I have bought. I rma the first set, but I think there is some other problem. I have eliminated caching and stealthing in the bios and still have the problem. I am would like to get the 4GB to boot into Vista 64. Any suggestions on what to do? I am dumbfounded on why memtest passes 1 stick installed (tested both sticks this) and when installed together, they fail.
