5.25 floppy drive not found
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I just purchased a new computer and installed my old 5.25 floppy drive (to burn old data to CD) and windows XP did not find the drive? Are there some settings so that the floppy drive will be found?
Go into BIOS at startup and select the appropriate floppy drive..
"TG" <anonymous@discussions.microsoft.com> wrote in message
news:E4AA8BE9-AA23-495C-96CC-993051776DAE@microsoft.com...
Yes, I did that and it still did not find the drive?
----- Mike wrote: -----
Did you go into the BIOS and change the setting which allows the 5.25 inch
floppy to be used?
yes
----- Papa wrote: -----
floppy to be used?
Take a look into the Device Manager and see if it lists the 5.25 floppy
drive. Also put a bootable floppy in your 5.25 floppy drive and see if it
boots. Make sure you have specified the appropriate 5.25 in your BIOS -
there are choices within that particular size. Did you assign the 5.25 as a
B drive? Is it listed on the screen as you boot up (before going into
Windows)?
Finally, are you sure that the 5.25 drive is functional, and are you using
formatted disks?
Good luck.
news:9F4E19FF-5997-41DA-A774-7C4FA9BFD562@microsoft.com...
> yes
inch
> floppy to be used?
drive (to
there some
I looked in device manager and only found the floppy controller, and no floppy drive.
I assigned the 5.25 as the A drive, as I disconnected the 3.5 floppy drive
I assigned the 5.25 as a 1.2mb drive in the BIOS (this is the correct size)
When I put a floppy in the drive it starts to spin, hence has power.
I will try the boot idea (it will have to wait, I have put the 5.25 drive back into my old computer to do some copying) and it is working fine.
Thanks,
TG
Windows)?
formatted disks?
Good luck.
> yes
inch
> floppy to be used?
drive (to
there some
TG, you might want check and make sure youe floppy cable is properly seated at both ends.
I do not believe that the 5.25 drives are not supported in XP.
news:647F2A02-8FDD-4053-BDCF-DADEB548CD39@microsoft.com...
drive (to
there some
You know Yves I think your absolutely, dead on, right. I don't why I didn't see that? I was thinking 3.25 innch floppy. I haven't even seen a 5.25 floppy, since about 1987.
You are correct. See the following Microsoft Knowledge Base article 309623.
http://support.microsoft.com/default.aspx?scid=kb;en-us;309623
"marken" <anonymous@discussions.microsoft.com> wrote in message
news:9368E8FB-6794-40AE-A854-4C866587B100@microsoft.com...
Actually, you can read and write to them in XP. You just can't format them.
"Papa" <bikingis@my.fun> wrote in message
news:%234ZDdBIMEHA.3216@TK2MSFTNGP12.phx.gbl...
309623.
On Sat, 1 May 2004 07:41:02 -0700, "TG"
Windows XP does not support 5.25" drives.
Peter Hutchison
Windows FAQ
http://www.pcguru.plus.com/
"Peter Hutchison" <pjhutch@NOSPAM.plus.com> wrote in message
news:g81l90hal8o0q30rjlc78h4e2b2ehsb9fv@4ax.com...
floppy drive.
drive
size)
> Peter Hutchison
> Windows FAQ
Not quite true. XP does not support formatting 5.25 inch floppies, but it
will allow reads and writes.
See: Floppy Disk Formats That Are Supported in Windows XP
http://support.microsoft.com/default.aspx?scid=kb;en-us;309623&Product=winxp
Windows XP supports the following floppy disk formats:
1.44 megabyte (MB) 3.5" floppy disk (read, write, format)
720 kilobyte (KB) 3.5" floppy disk (read, write only)
1.2MB 5.25" floppy disk (read, write only) <-----
360KB 5.25" floppy disk (read, write only) <-----
> Peter Hutchison
> Windows FAQ
Papa Wrote:
> "Peter Hutchison" pjhutch@NOSPAM.plus.com wrote in message
> no
> floppy drive.
> drive
> size)
> drive
> Peter Hutchison
> Windows FAQ
> it
Thought you might be intrested. Tried to install a 5.25" 1.2Mb drive
under XP and the only way XP would recognize and show the drive in
explorer was if the 3.5" drive was connected as well. Again the BIOS
had to be correctly set A: 3.5" 1.44mb b: 5.25" 1.2mb.
Whiteman
Sounds like a misplaced jumper or BIOS setting to me.
r.
"Whiteman" <Whiteman.1hoxh1@pcbanter.net> wrote in message
news:Whiteman.1hoxh1@pcbanter.net...
>> no
>> floppy drive.
>> drive
>> size)
>> drive
>> Peter Hutchison
>> Windows FAQ
>> it
> Whiteman
MS has decided to stop supporting 5 1/4 floppy drives. You can not normally
format the 5 1/4 floppies.
>> no
>> floppy drive.
>> drive
>> size)
>> drive
>> Peter Hutchison
>> Windows FAQ
>> it
> Whiteman
>>> no
>>> floppy drive.
>>> drive
>>> size)
>>> drive
>>> Peter Hutchison
>>> Windows FAQ
>>> it
"Yves Leclerc" <yleclercNOSPAM@maysys.com> wrote in message
news:uZkcpuQ6EHA.1452@TK2MSFTNGP11.phx.gbl...
> normally format the 5 1/4 floppies.
Legacy devices are controlled by the MB not the OS. Also FAT16 IS FAT16.
