[SOLVED] 6+2 pin to 6pin not working.
Adam20
13
Hi!
I bought an EVGA 600W that has a 6+2 pin and my graphics card only accepts 6pin. I plugged in the 6pins without the 2 and it boots up with no display.
How can I fix this? My graphics card is the Nvidia Quadro 4000
Any help is appreciated!
This is a hp system. Hp uses a TON of nonstandard connectors, and sometimes 24 pins with nonstandard pinout. I have seen the latter with a dell I had.
I would bet HP made it so you cannot easily upgrade the psu in this system.
