Quick questions: I have the RX 580 Red Devil. It has a 6 Pin and a 8 Pin connector. Which pin am I supposed to hook up with? My RM650x does have both pcie pin connectors. Why do they make two different pins port? And, does it matter which I use?
You need to plug in ONE 8-PIN, and ONE 6-PIN PCI-e cable to the gPU. Your card requires both.
Will this damage anything by using just one port?
because I just now was using one pcie connector to run the 6pin and 8pin. Is it ok to using one pcie cable from the psu that has a 6pin and 8pin splitter?
Yes, and I think you have done it correctly as well, as evident form the pic. 8+6-PIN PCI-E connectors. Splitter doesn't matter, as long the cable provides BOTH the 6 and 8-PIN power to the GPU. All PCI-e cables come with a splitter, 6+2-PIN.
There are no separate 8-PIN PCI/PEG connectors.
