Hello folks,
Bought a new 6850 last week to be able to play some of the newer games coming out. I was able to install it even though it was a bit cramped (had to switch around some sata cables where they connect to the mb) and played for a couple of days.
I got some right angle sata cables hoping I could use the connections I partially blocked with the card but it still wouldn't fit. So I put it back to the way it was, when it worked, and now the computer has a "code 43" error
-Windows has stopped this device because it has reported problems. (Code 43)-
Now I have no idea what to do. Tried reseating the card about 8 times, reinstalled the drivers and neither has worked.
I'm currently on that computer, it's outputting to the monitor but isn't really "working."
So, did I damage something during the reinstall, did the card die, or something else? Any help is greatly appreciated. Purchased the card from newegg less than a week ago and really don't want to replace anything I don't have to.
Thanks for your help.
Core 2 Duo E7500@2.93
6Gb DDR2 1600 ram
Vista 64bit home premium
500W antec power supply
6Gb DDR2 1600 ram
