Here are my specs:
CPU - AMD FX-6330
MOBO - MSI 970A-G43
GPU - Sapphire R9 280X
RAM - G.Skill Ares 16GB (2x4GB) DDR3
PSU - Cybertron SL-F500 500W ATX
In the Picture, the PSU only provides 6+2 pins while my GPU requires 6x2 pins, im considering to use on of the "6 pin PCI Express Power Splitter Cable" I found on Amazon.
But after checking on stability of these cables, it seems like those PSU that are poorly designed would not be stable at all, even some had their connector ports burnt out. (between the splitter and the PCI-E cable itself)
All I could think of is to ask those who had the experience doing so, if you did it, was it successful in long-term and/or stable?
Now for those who said no without actually ever using a power splitter, what would be the best budget PSU that handles enough wattages and has all the required ports? (CPU needs 4x2 pin)
CPU - AMD FX-6330
MOBO - MSI 970A-G43
