James i5
24
Hi all.
would this card:
AwesomeLinkHERE
run games on high to very high settings at 720p (1280x720)
its a 32" lcd
i sit 6 feet away from the screen
should I get a 1080p monitor?
games in mind are
Guild Wars 2
planetside 2
Skyrim
Battlefield 3
Thanks for replys :D
if you do suggest a better graphics card or monitors my price range is 150$
verdenshersker
251
I'm not sure about Battlefield 3, but I'm pretty sure the rest will run fine for that!
I know, I can play Skyrim maxed out in 1920x1200 with a GTX 550 Ti - which should be about the HD5770.
But if you are buying a card now, I would look for something newer? Unless you can get it used or so. I bought my GTX 550 Ti used for $60 and it was worth it!
