Hi, after posting a recent thread on specs for my new pc somebody asked me what sort of monitor I would be using. I hadn't really thought about that so decided to open a new thread in the graphic section as I thought it would get better replies.
The main problem that I have is 1080p vs 720p. I now the difference 1080p makes on things like a 42" TV (we have one in our living room and the picture is amazing) but I have heard that on smaller monitors, ones like under 24" you can't tell the difference. Another problem that I have is my budget of around £450. I know this isn't much money but it is the most that I can afford. I have been looking at 2 different monitors. A 22" 1080p monitor for £86 and a 18.5" 720p monitor for £60
1080p: http://www.misco.co.uk/product/Q571628/AOC-E2250Swdak-22inch-LED-DVI-Monitor
720p: http://www.waeplus.co.uk/product/2101501/LG-E1942C-BN
They both have 5ms response times and other similar things such as that. Unlike a lot of people however I aren't too bothered about screen size. I am currently using a 15.6" laptop so a 19" monitor seems huge. Also the space on my desk will only just fit a 19" inch screen on when I tested(it would be very annoying if a had to take my desk apart just to fit a monitor). This is the graphics card that I am going to be using, it is a XFX DD Core Edition Radeon HD 7770 1GB GDDR5. It has one dual link dvi, a display port and a hdmi.
graphics card: http://www.scan.co.uk/products/1gb-xfx-radeon-hd-7770-dd-core-edition-4500mhz-gddr5-28nm-gpu-1000mhz-640-cores-dp-dl-dvi-i-hdmi
The 720p monitor only has a vga input whereas the 1080p has both a vga and a DVI-D. The 1080p monitor also has speakers. But this isn't a important point as I will be using headphones for gaming and a iPod docking station for anything else.
Thanks in advance for any replies.
P.S- when you first turn a pc on to install windows do you need a wired keyboard or will a wireless keyboard and mouse work?
