Hi everyone, I just need some advice on a buy
I am currently running a computer with 8800GT in SLI, quad Q6600, 8gb ram, 1 dvd player/burner... Nothing TOO fancy
Anyway, I currently own a RP-650-PCAR which fan died and brought the PSU down a notch. So, it can't perform anymore and when there is a load on the computer (let's say game with nice graphics) my computer gives me a nice BSOD.
All worked fine for the year before tho
So I'll switch the PSU, Now... I am hesitating between a bunch of stuff because I don't know that much about computer hardware and I am seeking advice.
Should I replace it with the same model?
If not, I was looking on TigerDirect and NCIX (yes Canada) and I found those that seemed to be adequate... any advice?
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2235424&CatId=2036
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3438609&CatId=2036
Or should I buy something totally different.
Thanks in advance
Thanks in advance
