I recently put together my first 100% unstable system that I have ever built. Basically here is the major issue. The RAM runs 100% stable if it is in all in the same bank (Non-Dual Channel) I bought The Kingston 1g Chips that Giga-Bytes web site states are compatible. I do not overclock. Everything was at Normal settings.
When I put the RAM into Dual Channel configuration. The Board will randomly generate a BSOD with a BCCODE 124 (Or was it 224) at 1.8v. If I up the voltage to 1.875 volts the frequency of these crashes DRAMATICALLY decreases. At 1.8v it's about every 30m - 60m that it crashes to a BSOD. at 1.875 volts it's once about every 3 hours. At 1.9v it happens every faster and faster. NOTE that if the RAM is not in Dual Channel mode, it NEVER happens.
My question is pretty basic. Does anyone know what might be causing this?
I tried the timings at defaults for the SPD and for the RAM at all voltages. I am about to order a new board. To I bother getting a new DQ6? Will I run into this again with all of them cause I'm doing something wrong? Help if you can... please.
Dave
Dave
