- Delta Industrial fans
I looked up those fans. They're cool. Will probably use them in my next build.
Best fans on the market, in terms of performance.
Consumer option would be Noctua. But Delta Industrial is best in the world.
- Arctic Silver 5, One of the poorest thermal pastes out there.
That does hurt me a little. Back when I bought it, it was debated on forums and said to be very good. I guess I was misinformed. No matter, thank you for the suggestions, changing the paste will be my first step.
Anyone can debate in the forums and praise the product they have fondness of. E.g i've seen complete crap of PSUs praised to high heaven, but that doesn't mean the PSU IS actually good. (Unless we are the Orcs from Warhammer 40K and our belief alone can make the product good.
Or on another sense; when someone claims that driving drunk is safe and should be done without concern, would you drive drunk? If not, then why not?
As far as Arctic Silver 5 goes, don't confuse it with Arctic Cooling (usually referred to as "Arctic". E.g Arctic MX-4 i talked above.) Arctic Silver and Arctic Cooling are two different companies. Arctic Silver only has 3 thermal products in their entire lineup (
homepage), while Arctic Cooling is one of the best PC cooling companies out there, by making great AIOs, air coolers and case fans, among other products (
homepage). E.g my CPU cooler is Arctic Cooling Freezer i32, usually referred as "Arctic Freezer i32" combined with Arctic MX-4 thermal paste. Oh and i replaced the stock fan with 2x 120mm Corsair ML120 Pro red LED fans (for better performance and in push-pull).
But as far as thermal paste itself goes, 10 years ago, there was a huge testing and roundup of all kinds of thermal pastes. Here are the results for high mounting pressure on air coolers (essentially what you have with your NH-D15),
link:
https://www.tomshardware.com/reviews/thermal-paste-performance-benchmark,3616-18.html
- Run in negative pressure and look if your CPU temps improve.
That's.... an interesting take. Most of what I said strongly suggested going for positive air pressure for both cooling and dust accumulation and more. Still, I don't mind doing the test. Will change my fan speed to inverse the pressure and test my temps.
I'd like to see the one who claims that positive pressure is best in terms of cooling.
Since the reality is, that while positive pressure is best against dust accumulation, it is the worst in terms of cooling, compared to other two: neutral and negative pressure.
Rule #2: Have More Exhaust Fans Than Intake Fans (Negative Pressure)
This is important to remember because having more intake fans (Positive Pressure) than exhaust can lead to stagnant air. Stagnant air leads to higher internal temperatures since there aren't enough fans removing the heated air from the inside of the case. In general, positive pressure doesn’t cool as well as negative pressure will. That said, one of the benefits of Positive Pressure is that less dust will enter the system.
Negative pressure provides the best cooling performance for enthusiast (often heat intensive) builds. It builds on natural convection and works with graphics cards.
Source + further reading:
https://forums.tomshardware.com/thr...-fans-and-keeping-your-computer-cool.1542215/
And to add to the above (which isn't included in article); negative pressure works like vaccuum, where as soon as the hot air is produced, it will be sucked out of the PC case, thus providing better cooling to PC components.
And here is visual demonstration of all 3 pressure systems as well, in a great looking PC case (Corsair 760T);
View: https://www.youtube.com/watch?v=sh6F2eccMec
- What makes you think that AIO can beat king of air coolers
I love my NH-D15. I would never say anything wrong about it. Still, it's just a fact that water cooler have a higher temperature transfer coefficient than air. Combine that with a much bigger radiator meaning bigger dissipation surface and more fans / air cooling meaning better cooling overall. NH-D15 is great, really really great, but as far as my own research have indicated big AIO (240 and especially 360mm) have better overall efficiency.
It is true that AIOs have bigger surface area than air coolers (due to the rad) and it takes far longer (usually 30mins) until liquid in an AIO heats to the max it can get, but there are downsides to the AIOs as well.
As far as AIOs vs air coolers go, you won't gain any cooling performance, if you go with AIO over air cooler, since both, in the end, are still cooled by ambient air.
For equal cooling performance between AIOs and air coolers, rad needs to be 240mm or 280mm. Smaller rads: 120mm and 140mm are almost always outperformed by mid-sized air coolers. Single slot rads are good in mini-ITX builds where you don't have enough CPU cooler clearance to install mid-sized CPU air cooler.
Here are the positive sides of both (air and AIO) CPU cooling methods;
Pros of air coolers:
less cost
less maintenance
less noise
far longer longevity
no leakage risks
doesn't take up case fan slots
additional cooling for the RAM
CPU cools down faster after heavy heat output
Pros of AIOs:
no RAM clearance issues*
no CPU clearance issues
CPU takes longer time to heat up during heavy heat output (about 30 mins)
* on some cases, top mounted rad can give RAM clearance issues
While how the CPU cooler looks inside the PC depends on a person. Some people prefer to see small AIO pump in the middle of their MoBo with tubing going to the rad while others prefer to see big heatsink with fans in the middle of their MoBo.
Main difference between AIO and air cooler is that with AIO, you'll get more noise at a higher cost while cooling performance remains the same.
Here's also one good article for you to read where king of air coolers (Noctua NH-D15) was put against 5x high-end AIOs, including former king of AIOs (NZXT x61 Kraken),
link:
http://www.relaxedtech.com/reviews/noctua/nh-d15-versus-closed-loop-liquid-coolers/1
Personally, i'd go with air coolers every day of the week. With same cooling performance, the pros of air coolers outweigh the pros of AIOs considerably. While, for me, the 3 main pros would be:
1. Less noise.
Since i like my PC to be quiet, i can't stand the loud noise AIO makes. Also, when air gets trapped inside the AIO (some AIOs are more prone to this than others), there's additional noise coming from inside the pump.
2. Longevity.
Cheaper AIOs usually last 2-3 years and high-end ones 4-5 years before you need to replace it. While with air coolers, their life expectancy is basically unlimited. Only thing that can go bad on an air cooler is the fan on it. If the fan dies, your CPU still has cooling in form of a big heatsink. Also, new 120mm or 140mm fan doesn't cost much and it's easy to replace one. While with AIOs, the main thing that usually goes bad is the pump itself. And when that happens, your CPU has no cooling whatsoever. Since you can't replace pump on an AIO, you need to buy whole new AIO to replace the old one out.
3. No leakage risks.
Since there's liquid circling inside the AIO, there is always a risk that your AIO can leak. While it's rare, it has happened. It's well known fact that liquids and electronics don't mix.
- Your Corsair Obsidian 500D RGB SE is a hotbox
Well, I did mention I knew this case wasn't at the top of the airflow chart. Still, it's not at the bottom either. Let's just say it's middle of the pack. Meaning that there shouldn't be any issue if running stock pc parts with a few fans. I completely agree that I could've picked a better case but back then I didn't know better so I'm just happy I didn't pick a terrible one ^^.
Any PC case with solid front panel can't be called "middle of the pack" since the main source of intake air is restricted considerably. Now, there are ways of mitigating that, e.g running high static pressure fans on high speeds, so that the fans have the power to pull the air in between the small gaps at the front panel, but that will lead to high audible noise. Both what the fan itself produces and airflow being pulled through the small gaps.
Moreover, i wouldn't say that your PC has "stock parts". You have Core i9 in there with beefy GPU (and while you didn't say which GPU you have, i'm sure it's also high end. Or in other words, i don't think you'd be using iGPU.) "Stock parts" would be Core i3 or i5 with GTX 16-series GPU and then, the Corsair 500D would be fine in terms of temps. But yours is high end. And with high end components, you will get a lot more heat production, than with "stock parts".
I see that you haven't done the simple test i asked of you. By running your build without front panel. I suggest that you do that. Take the fancy tempered glass front panel off, dust filter too and run bare fans on front. Look if your CPU temps drop. I'm quite sure it does.
Once you've done this simple test, there are ways on moving forwards. Best option would be replacing the PC case with better one, the one that has grille/mesh at the front and not a solid panel (be it metal or TG).
But if you want to keep your fancy aquarium, you can still do that. Then, one option is where you need to install high static pressure fans at the front, and run them on higher speeds, so that there is enough airflow through the front. But like i said above, downside is high audible noise.
Another option is running negative pressure. This way, you can keep your fancy ARGB fans on the front, spinning somewhat, where their only purpose is providing eyecandy. While running the top 2x 140mm and rear 1x 120mm exhaust fans at far higher speed (to create negative air pressure).
