A Case with 2 power supplies .
The_Spy
I have a case with 2 power supplies the one is connectet to my mainboard and the fans and the other is conecte to my 2Hdd's Dvd floppy and cd-wr .For the time is warking perfect .Id like to ask if its going to be a problem in the futer on my Hdd's note the one psu is Atx and the other is At
....Just like the lust time.
Why would it be a problem? I actually recommend AT power supplies when people want to power their drives off a separate supply.
<font color=blue>You're posting in a forum with class. It may be third class, but it's still class!</font color=blue>
How is the AT supply turned on? Preferable it should be powered up at the same time as the ATX supply.
<i><b>Engineering is the fine art of making what you want from things you can get</b></i>
<A HREF="http://www.btvillarin.com/phpBB/viewtopic.php?t=655" target="_new">My systems</A>
Thanks for the advises.The psu's separetly turn off/on and i am thinking to connect the at cable on the atx cable so they are going to turn off/on at the same time
Sorry but that isn't possible as the AT PSU uses a switch which is directly connected to the electricity input.
ATX PSUs use a diffirent power on style with a low voltage line connected to a button (not a switch) to give a power on signal.
Just power on the drives first and then your mobo.
My CPU runs so hot the arctic silver undergoes nuclear fusion 😱 .<P ID="edit"><FONT SIZE=-1><EM>Edited by svol on 12/07/02 02:55 PM.</EM></FONT></P>
