- Which CPU is better in terms of lifespan between AMD and Intel, if I will not overclock them ?
- Which CPU runs hotter ?
- What are the maximum normal temperatures for AMD ?
- What are the maximum normal temperatures for Intel ?
- What is the maximum normal voltage for a AMD CPU ? I saw in some screenshots a maximum of 1.5V, but some people said that is too high... If I will buy AMD, then I need to set the voltage in BIOS ?
- What is the difference between AMD and Intel motherboards in terms of power "phases" ? I saw that some MB have mentioned the number of phases and some of them not.
