A little bit of help , PLEASE ! GA-945P-S3
justanuser
Hello . I have a small (big , don't know for sure) problem . I've tryed all kind of programs to see my motherboard temperature , but all of them ( SpeedFan , Everest Free etc.) tell me the motherboard temperature is the same as the CPU temperature) . If for example the CPU temp is 45 C , then the motherboard temp also shows 45 ; if it shows 46 C - then motherboard temp is also 46 etc .
Basically , it show the temp of the CPU instead of the mobo.
I don't know if that's ok , or if there is a problem .
Here are my hardware conf , I just copy/paste from the gigabyte web , where i posted this problem , but after many days , no answer.
PLS help . Awaiting for your response , thank you .
Model Name : GA-945P-S3(rev. 1.0)
M/B Rev : 1.0
BIOS Ver : F5
Serial No. :
Purchase Dealer :
VGA Brand : Nvidia Model : 7300GT
CPU Brand : Intel Model : Pentium D 820 Speed : 2800
Operation System : Win XP SP : 2
Memory Brand : Type : DDRII
Memory Size : 512 Speed : 667
Power Supply : 450 W
No , i haven't just bought the mobo . I have it for 5 months , something like that , but it didn't bother me that it shows the same temp as the proc , until a week ago , when i just wanted to find out what is the matter , if there is a BIG problem .
Anyway , the revision is 1.0 , and the BIOS version was F2 , but I updated it to F5 recently (to see if it fixes the problem) . F5 is the lastest on the gigabyte website for rev 1.0.
Well , I just tested the pc wizard 2007, and the same . It shows that the mobo temp is exactly as the cpu temp. 🙁 . Ty anyway for your advice .
What could it be ? :?: :?
For a good system tool, do google search on SANDRA. There is a free system analyzing/optimization utility you can DL. I am using it on my 965P-DS3 and it shows both CPU/Board temps,voltages and fan speeds. I hope it worksfor you.Good luck.
