[SOLVED] a Seagate hard drive says "dell" on it, does it matter?
Oct 8, 2020
4
I found a drive on eBay and I was thinking of buying it. it's a "dell" drive that was manufactured by Seagate. I was wondering if this drive would act differently from a normal Seagate drive. if it helps, the seller listed the drive as "Seagate ST8000NM0055 8TB 256MB 3.5" SATA 6GB/s 7200RPM DELL PN 0T05HP"
It came out of a Dell system.
But...buying a used HDD from fleabay? Only if it were really really really cheap. Like $25 for an 8TB.
It’s 100 dollars, I think that’s a pretty good deal. So just to confirm, it doesn’t matter? Dell wont use a different hard drive software or something?
