This www.sharkyextreme.com/hardware/videocards/article.php/3211_3746916__9 review mentions using RivaTuner with success :
Quote:
The Gigabyte Radeon HD 3870 512MB offers a specialized version of the GDDR3 model, with a custom cooling solution and Ultra Durable 2 components, so we were very interested in how the card would overclock. The default clocks as measured by the ATI Catalyst Information Center and OverDrive tabs were 780 MHz core and 1900 MHz GDDR3 memory.
OverDrive's automatic tuning mechanism resulted in an overclock at 870 MHz core and 2080 MHz memory speeds, which represents an approximate 12% jump to the core speed and almost a 10% increase in the memory clock. We were able to take the card to the limits of OverDrive (880 MHz core/2100 MHz memory), but subsequent testing in RivaTuner showed this to be extremely close to its limit for a 100% stable overclock.
Keep in mind that this overclocking data is based on one card, and as with most things in life, your mileage can definitely vary.
*This is info i know works for the GDDR4 version:*
There is the 3870 Update BIOS
v010.071 knocking around, that'll help you overcome the wall you generally hit at 865mhz core. Also you can
volt mod the 3870 though there are no voltage soft mods as the voltage regulators are fixed.
I used
winflash to do may cards, though there are others. Make sure you read the instructions fully and make a backup of your current 3870 BIOS.
Although my cards in crossfire don't hit above my sigs spec's, i have overclocked one of them (on water mind..) to 940Mhz core max run and 900Mhz core (Furmark stable) on stock voltage
It is a risk to flash your BIOS, but it's your decision if you try it
