A7V8X-X - Max hard drive size?
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I've got an A7V8X-X Rev 1 with BIOS 1007. What is the largest hard drive I
can install without using any overlay software?
There is a chart on the Asus website but the my board isn't on the list.
There is an A7V8X on there but thats somewhat different.
Thanks
megashorts
Gamertag: megashorts
Take out the trash to reply by email!
In article <isNrc.13144$jz3.11802@fe22.usenetserver.com>,
> Thanks
> megashorts
http://www.asus.it/support/english/techref/48bithdd/index.aspx
At the top of the page in red text, it says:
"Note: Model manufactured after 1st January, 2003 will all
support 48bit HDD (137 GB HDD)"
If you go to a download directory, the earliest file in the
directory is Feb 2003, so it is just "over the line".
ftp://www.asuscom.de/pub/ASUS/mb/socka/kt400/a7v8x-x/
So I'm guessing it supports disks larger than 128GB/137GB
(binary/marketing GB).
HTH,
Paul
>>Thanks
>>megashorts
> HTH,
> Paul
the 250 gig WD works fine straight up
> >>I
> >>Thanks
> >>megashorts
> > HTH,
> > Paul
Thats what I wanted to know!
The Asus info was why I asked the question in the first place!
Thanks
Megashorts
"Megashorts" <megashortstrash@yahoo.com> wrote in message
news:isNrc.13144$jz3.11802@fe22.usenetserver.com...
I have just installed two 160GB drives on an A7N8X-X board, under the Bios
they saw the whole 160Gig, however under Windows 2000 Pro the only showed
about 128Gig until I downloaded a registry hack from the Maxtor site.
Adam S
