Abit NF7-M boot problem (no signal to monitor)
Mode_Locrian
21
Well, I'm somewhat at a loss for how to troubleshoot this, as I can't even get a signal to my monitor to get any feedback in BIOS as to what is going on.
Here is my system:
Abit NF7-M
Athlon XP 2700+
Corsair Value Select PC2100 (2x256MB)
Antec PSU (came with the case; 350W)
When I turn on the system power, both LEDs on the motherboard come on, indicating that the motherboard has power and that system power is on, according to the manual. All fans and case LEDs work correctly.
Sadly, that's about all that's working right, as far as I can tell. There is no signal being sent to my monitor from the onboard video of the motherboard. I also tried putting in an old GeForce4 MX AGP card, which I know works (it's providing the video for the monitor I'm looking at now), and that didn't work either.
Any ideas as to what might be going on? I had a bit of a hard time getting the HSF on the CPU, so I am a little concerned that I might have damaged the CPU in the process. I will look into that tomorrow or Friday when I'm not so tired.
If the CPU isn't the problem (crossing my fingers), any other suggestions as to what the problem might be? I've built a couple systems before, but I've been fortunate enough in the past not to run into any tough troubleshooting issues like this.
Any help would be greatly appreciated.
ASUS K8V Deluxe SE | Athlon64 3200+ | Radeon 9800 Pro 128MB | 2X WD Raptor 74GB (RAID0) | 2X OCZ 512MB (PC3200, 2336) | SB Audigy2 Platinum
What is the FSB of your processor? Is it a 133 or 166 version? I notice that the RAM you are using is DDR266, which works great if the FSB is 133. If the FSB is 166, you need DDR333 (PC2700) RAM. If thats the case, that would explain why its not booting.
XP2800+, Abit NF7, 1GB Dual-Channel DDR333, ATI R9800PRO 128MB, TT PurePower 420W, LG DVD+-R/RW
:redface: <font color=red>My wife says I suffer from premature ejaculation...I don't remember suffering<font color=red> :wink:
Here is my processor: <A HREF="http://www.newegg.com/app/viewproductdesc.asp?description=19-103-342&DEPA=0" target="_new">Description on NewEgg</A>
According to the description, it has a 333Mhz FSB.
How can I "set the memory to 133"? Recall that I can't get into BIOS to change any settings. Is there some way that I can directly modify the speed on the stick of RAM or something?
Thanks for your help so far.
That's exactly what happens when you forget to plug in the 4 prong CPU power plug. Double check it. Been there, done that!
Abit IS7 - 3.0C @ 3.6ghz - Mushkin PC4000 (2 X 512) - Sapphire 9800Pro - TT 420 watt Pure Power
Samsung 120gb ATA-100 - Maxtor 40gb ATA - 100
Sony DRU-510A - Yellowtail Merlot
System powering up without response is normally caused by the ATX12v (4-pin square power connector) not being connected to the board, OR a damaged CPU, OR a reversed IDE cable. Since all modern IDE cables are keyed, I'll have to go with one of the first 2 causes.
<font color=blue>Only a place as big as the internet could be home to a hero as big as Crashman!</font color=blue>
<font color=red>Only a place as big as the internet could be home to an ego as large as Crashman's!</font color=red>
Well, thanks for all the help, everyone. I solved the problem this morning. Crashman was closest to giving the right diagnosis; the CPU wasn't quite all the way into the socket. I was lucky that I didn't crack the core in putting the HSF on, but I carefully reseated the CPU and everything works great now.
Wow, that one must have slipped my mind! After all, how many times have I seen it! Let me count....Never, sorry. But I'm glad you figured it out!
