So my cat knocked over a cup of water and it spilt mostly 90% on my desk; however some fell on the top of my PC (It was on; but I instantly shut it down as I saw it happen). My PC has open holes at the top and then a second layer underneath where all the USB/ETHERNET cables connect before any of it reaches my components.
I took off the lid and all the sides, plus the back section and checked for wet spots. I couldn’t find anything besides a single droplet on the PSU case on the top, and I checked all around it to make sure there wasn’t any gaping puddles.
I checked the CPU, GPU and HDD/SSD’s and I couldn’t find any massive amounts of water either, a single droplet maybe on a casing in that section; they’re not flat laying down etc they’re like on a side angle. The water was mainly on the fans; in which I removed and dried properly and double checked before putting them back in and I dried around the entirety of the case and inside too and once again double checked for any missed water and I couldn’t find any. Most of the water was stopped by these dust protectors I have or was largely on the fans.
I turned it on briefly after drying it all to check it turned on and it does and there is no issues with anything. I checked the temperatures of the fans and they were fine as are the temperatures for everything else. The RGB works on everything still too, I checked all the systems were working and connected - Internet, Mouse, Keyboard, HDMI and those are fine too. Then I turned it off after briefly checking all those.
Now I just want to know how long should I keep it off to make sure it’s dry. My house is pretty warm currently so I am not sure if that will make a difference. Any suggestions would be great.
