Accidently uninstalled DirectDraw! Help!
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.games (More info?)
I had errors with starting my games lately, such as the Sims2 and Ragnarok
Online. But I had no problems a few mnoths ago when starting games like these.
My Nvidia GeForce 420 graphics unit isn't obsolete, and supposedly I've
installed DirectX 9.0c. However, when I run DxDiag, I find that my computer
is missing DirectDraw and Direct3D! I think I must have uninstalled them by
accident.
I absolutely am having a hard time finding any sort of help on what to do
with this issue. Is there any way I can possibly get DirectDraw and Direct3D
back onto my computer? Is there a place when I can download the files again?
Thanks in advance!
Hi Nyewy,
Try the complete Installation Package for DX 9.0c:
http://www.microsoft.com/downloads/details.aspx?FamilyID=9226a611-62fe-4f61-aba1-914185249413&displaylang=en
Let me know if you have any problems. 🙂
Cheers, Windows XP MVP Shell / User
Jimmy S. http://mvp.support.microsoft.com
Game FAQs: ;gms]http://support.microsoft.com/default.aspx?scid=FH;[LN];gms
Visit my MSN Zone.com and Gaming Help Site: http://mvps.org/nibblesnbits
MS Assisted Support: http://support.microsoft.com/select/?target=assistance
My advice is donated "AS IS" without warranty; nor do I confer any rights.
_________________________________________________________
"Nyewy" <Nyewy@discussions.microsoft.com> wrote in message news:89BDDCA8-8850-44EC-94CE-5585376BCFE6@microsoft.com...
> accident.
> Thanks in advance!
Unfortunately, I really don't know where to place it, as it prompts me to
save the fiels to a directory after I've downloaded the file. The field is
blank, so I really do not know where to begin. I put them in the
programs/directx/ folder, but nothing has improved yet. =/ Could you please
give me a ltitle more advice on this?
Thank you so much!
"Jimmy S." wrote:
> Hi Nyewy,
> > accident.
> > Thanks in advance!
Hi,
Save the .exe file to your desktop and once the download is complete
you can then double click that setup file to install DirectX.
"Nyewy" <Nyewy@discussions.microsoft.com> wrote in message news😀8B180A2-AD0F-4B44-89B2-F87AC77971CF@microsoft.com...
> Thank you so much!
> "Jimmy S." wrote:
>> Hi Nyewy,
>> > accident.
>> > Thanks in advance!
Yes, I saved and ran the file before, but I meant when I do run setup, and I
accept the terms of agreement, a box pops up that prompts me to "Please type
the location where you want to place the extracted files." But, I do not know
where to direct the setup to install the files to. Could you tell me where
the appropriate location is?
Thanks for your time still. ^^;
"Jimmy S." wrote:
> Hi,
> > Thank you so much!
> > "Jimmy S." wrote:
> >> Hi Nyewy,
> >> > accident.
> >> > Thanks in advance!
Hi Nyewy,
To be on the safe side, create a folder named TEMP on your
desktop and instruct it to extract the files there. Most likely it
will use that as a working directory to extract the files before
installing DirectX into it's proper location in C:\Windows.
Make sense? ;-)
"Nyewy" <Nyewy@discussions.microsoft.com> wrote in message news:05B6D8BA-D36B-40F5-AE9F-211475398D00@microsoft.com...
> "Jimmy S." wrote:
>> Hi,
>> > Thank you so much!
>> > "Jimmy S." wrote:
>> >> Hi Nyewy,
>> >> > accident.
>> >> > Thanks in advance!
Alright, I've created the temp folder, extracted the files to it, and
installed DirectX accordingly. However, my game still does not begin
whatsoever, and whenever i run DxDiag, I still see that DirectDraw is "not
available" though I can run diagnostic tests (which pass fine), as well as
Direct3D being "not avaible", and the option to run diagnostics tests on that
is not possible.
On th etoher hand, the front page of DxDiag shows that DirectX9.0c is
installed, and that I have the latest driver for my Nvidia GeForce 420.
Should i save my DxDiag settings so you could possibly take a look at them?
And I recently read that when installing Nvidia drivers, any virus
protectetion should be off--though I isntalled it with Norton Auto-Protect on
unawaringly. Should i try this again?
Thanks again~
"Jimmy S." wrote:
> Hi Nyewy,
> Make sense? ;-)
> > "Jimmy S." wrote:
> >> Hi,
> >> > Thank you so much!
> >> > "Jimmy S." wrote:
> >> >> Hi Nyewy,
> >> >> > accident.
> >> >> > Thanks in advance!
> is not possible.
Norton auto-protect generally creates more problems than it is supposed to
protect from, I'd remove this piece of software then remove the video
drivers via the XP control panel applet and re-install those drivers, DX
seems fine but not the video drivers...
Install the drivers from safe mode without network connection so no other
part of Norton like the AV interferes, what else did change on this system
since the games worked fine? Which other program/drivers did you install
since then? Did you try updating/re-installing the motherboard drivers?
All the Best
Katy Pluta
Latest posts
