So it all started a few days ago when I noticed my games were a lot laggier than usual, and a couple minutes later the display stopped and both my monitors said "No Signal" but the PC was still on (sound and RGB was still on). I forced shutdown and rebooted and it worked but started checking the temperatures, the CPU is around 40 degrees whereas the GPU is around 60-70 degrees idle and 80-95 degrees while gaming. This only started a few days ago and yes, I have attempted to clean out the system as it was quite dusty. Should I send it in to Acer for a repair or is it an easy 30 minute fix at home?
SPECS
Intel Core i5-9400F
8GB DDR4
Nvidia GTX 1650 4GB GDDR5
120GB SSD
1TB HDD
SPECS
Intel Core i5-9400F
8GB DDR4
120GB SSD
1TB HDD
