G
Guest
Guest
Hey guys, later on I plan to upgrade my case with some extra case fans but the problem is I don't have enough chassis fan headers on my motherboard to add in more fans, I have a Corsair 230T Graphite Series case that has two 120/140mm fan slots on the top & a 120mm bottom fan slot on my case. But at the same time I want to control the fan speeds, without any software.
I know this question has probably been asked before but I need to figure out a way to control all of my fans, including the ones that came with my case, two 120mm intake fans & a rear 120mm exhaust fan. I plan to use some PWM fans as well. I'm going to get an AMD R9 390 GPU also, so I have to worry about the temps.
