Advice for building a mediocre gaming PC
Supercell
I plan to build a PC by myself, need advice if the parts selected are not too good/bad in comparison to the rest of the machine before I buy them.
Approximate Purchase Date: Next week/two weeks
System Usage from Most to Least Important: Opening lots of programs, Gaming (Planetary Annihilation, Skyrim, Starcraft 2, Minecraft), Programming
Overclocking: No
SLI or Crossfire: No
Monitor Resolution: 1920*1080 (Don't have it yet)
Parts Selected: PC Part Picker List
CPU: Intel Core i5-4460 Haswell Quad-Core 3.2GHz
Motherboard: ASUS GRYPHON Z97
GPU: ASUS STRIX GeForce GTX 750 Ti
Case: Corsair Carbide Series Air 240
Memory: G.SKILL Ripjaws X Series 16GB (2 x 8GB)
PSU: CORSAIR CSM Series 450W
SSD: Crucial BX100 CT500BX100SSD1 2.5" 500GB
Additional Comments/Questions:
I usually play games that are heavy on the processor and don't care about graphics as much, but would like a GPU that can run at least my favorite games at highest quality.
I often launch many programs simultaniously therefore the 16gb ram (imagine 10 chrome tabs + modded minecraft server+client).
Asus Gryphon is supposedly good for long term builds, and I don't plan to switch rigs in the next 3-4 years. Some upgrades (especially GPU) might happen in a year though. It has a lot of features for cooling that I don't think I need, is this a hint it's way better then it needs to be?
Also since I won't overcloak, is the stock cooling enough?
I don't really understand the differences between memory models, so feel free to recommend better suiting models if applicable.
I have a big external HDD for rarely used files. Are SSDs reliable enough for constant usage over some years or should I get an additional HDD?
Z97 board, such as that one, with a locked CPU is overkill. You are overspending in areas, that you shouldn't at the cost of performance. I could have went with a better GPU, but kept the SLI capability. The GTX 750ti doesn't support it, and the GTX 960 does.
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor ($179.59 @ SuperBiiz)
Motherboard: Gigabyte GA-Z97MX-Gaming 5 Micro ATX LGA1150 Motherboard ($119.99 @ Directron)
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1600 Memory ($119.98 @ OutletPC)
Storage: Crucial BX100 500GB 2.5" Solid State Drive ($179.94 @ Adorama)
Video Card: EVGA GeForce GTX 960 2GB Video Card ($209.99 @ Amazon)
Case: Cooler Master N200 MicroATX Mid Tower Case ($39.99 @ NCIX US)
Power Supply: Antec High Current Gamer 620W 80+ Bronze Certified Semi-Modular ATX Power Supply ($68.00 @ Amazon)
Total: $917.48
Generated by PCPartPicker 2015-02-23 14:54 EST-0500
