Hello, I need you to rate this build
Motherboard: Asus P5Q Pro
CPU: Q9550 2.83Ghz, will be overclocked after like 1 year
RAM: 4Gb, but can't decide between A-Data G-Series, Kingston or PQI, 2x2Gb would be great.
HDD: WD Caviar 640Gb, 7200rpm, 16mb
GPU: either HD4870 1Gb(cheap one) or gtx280(expensive one)
because I'll be using 19" monitor, I think I don't need powerful card
Monitor: LG 19" 1440*900 Widescreen. Love that LGs have "4:3 in Wide" ability Also this is a cheap display with 2ms reaction time. Link with monitor
PSU: dunno how many watts will I need, guess 700W will be okay. I won't be crossfiring or SLi'ing. Keep in mind that I'll be overclocking later
Coolers: as cheap as possible, both CPU and System ones, stock on GPU.
Well, i think this build is flawless, but since I'm not a pro at hardware I might be wrong, please criticize. I've heard IP45 chipsets are better for Nvidia cards, while X48 for ATI. I've read that gtx280 needs 40A current and works @~280W when heavily loaded, will 700W psu manage this task?
