Do I need to manually adjust fan curve for my PC case fan or should I upgrade to better case?
I recently built my HTPC for gaming, hosting Plex server in my living room. I chose case form factor based on sleeper look and clearance under 7" in my living room shelf cabinet. It fits well placed in horizontal position. In summer it is usually warmer around 72-74F.
Most games I play are older and don't require much power and don't generate much heat, but I play regularly one game that push to limit (Jedi Survivor).
I get pretty good performance but I don't know how to feel about thermal performance. When playing the game, I push cpu and gpu to constant 80C (GPU 100%, CPU 20-30%) (max 82C).
Here are my specs:
Motherboard: Aorus B550M Elite
Case: Fractal Core 1100 (classic/legacy)
Case fans: 1x 92mm on the back(out), 1x 120mm on the front (in), 1x 120mm slim on the side (out) (front and side sharing same 4pin fan header)
CPU: Ryzen 7 5700x (no overclocking) with BeQuiet rock slim 2 cooler tower 92mm (max clearance)
GPU: NVIDIA GeForce 3080 FE
SSD: NVME WD_Black 1TB in heatsink
Idle temperature readings at room of 73F (23C):
cpu: 43C, 92mm fan speed: 1358rpm
ambient: 35C
ssd: 41C
Case fan back 92mm -1218 rpm, case front fan 120mm - 776 rpm
HWInfo temp reading 1
HWInfo temp reading 2
Front view of the case
Case side view
View inside the case
Here are my specs:
ambient: 35C
ssd: 41C
Case side view
