Hi all
the current PSU I have in a 12 year old rig is 14 pins and is currently supporting a GTX 670. I want to upgrade to GTX 1660 super (16 pins 2x8).
I have a 2x 6 pin and 1 x 2 pin. (14 pins)
After some research i can see that it might be possible use a molex adaptor. But most adapters i see have two ends for a molex with 3 pins in each molex end feeding a 8 pin for GPU. I only have 1 molex end available in the rig and not two. Does both the molex ends need to be connected? or only one?
Or i can see that the a 6 pin can be adapted to a 8 pin by one of these:
https://www.amazon.co.uk/Cable-Matt...dcce3&pd_rd_wg=KtP7u&pd_rd_i=B01DV1Z32Y&psc=1
Which will give me the extra 2 pins.
Or as i also have one of the newer psu leads available inside the rig for this type connection. Is this better?
https://www.amazon.co.uk/CGTime-15-...dcce3&pd_rd_wg=KtP7u&pd_rd_i=B075383P7T&psc=1
Not looking to replace PSU as i am uncertain if i can get a replacement to equal all the current required connections inside which i wont bore you all with. So looking to modify to get extra pins to work the GPU.
Some forums say i can just use the 14 and not worry about the remaining two while some advise against it.
What should i do?
Thanks
What should i do?
Thanks
