I have an Intel Q9300 Quad Core 2.4ghz processor with 1333mhz fsb (333mhz). I changed the fsb to 400mhz (1600mhz), but according to CPU-Z, my multiplier (unlocked-min. at 6, max at 7.5/actual value at 7.5) keeps changing between 6 and 7.5, changing my core speed from 2400mhz to 3000mhz repeatedly! The max fsb supported by the mobo is 1600mhz, so I can't overclock more than that. I have sufficient cooling, as my CPU generally stays around 30 degrees Celcius, and my motherboard generally stays around 43 degrees Celcius (according to bios, but I added 2-3 degrees). I OC'd through the ASUS motherboard's bios. Can someone help me out here please? Thank you very much in advance!
This is my mobo: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131336
Features: http://usa.asus.com/products.aspx?modelmenu=1&model=2413&l1=3&l2=11&l3=761&l4=0
Specs: http://usa.asus.com/products.aspx?modelmenu=2&model=2413&l1=3&l2=11&l3=761&l4=0
