G
Guest
Guest
I have looked for months to find a new graphics card for an older PC that I built, changing it from an AIW pro PCI card to an AGP card. Until now, I could not get a signal either through the VGA or DVI ports. I finally found one that provides a signal through the VGA port but no signal at all on the DVI port.
The card I finally found is a Sparkle Gforce FX 5500 AGP 4x/8x card, with both VGA and DVI-I ports. My monitor is a Princeton LCD17D monitor with both VGA and DVI-D ports. Again, connecting the VGA ports via a VGA cable, I get a normal signal. However, connecting the card's DVI-I port to the monitor's DVi-D port, via a DVI-D cable (which is supposed to be the pure digital cable for this), I get no signal, causing the no signal error beeps on boot, and the power light never turning green.
With the prior card trials where neither signal worked, I wondered about the AGP slot. However, as the VGA signal is great from this AGP card, I assume that the slot is ok.
I have tried the monitor front settings, however could only find that it noted ANALOG with the VGA connections. I could not find any setting change to DIGITAL, so I assume it is connecting automatically to the existing setting? As I cannot get any video on DVI, I cannot check this monitor setting to see if it turned automatically to digital.
Any suggestions?
Any suggestions?
