AIYEEEE! SOMEONE PLEASE HELP ME!
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.customize (More info?)
I just got a new Dell laptop with XP SP2. I am trying to assign full
read/write/execute permissions to a file. There are sharing and
security options, but none that give the ability to change read/ write,
etc. I know that such permissions were once there, especially on
Windows NT and 2000. Now there is no security tab on the file. Can I get
back to the normal security tab which allowed me to change permissions?
It should not matter if it is a Word document, picture, etc. In my case
it will be a .php file. Please do not flame or spam me.
Thanks,
David M. Schwartz
dmschwartz210@yahoo.com
On XP Home you have to logon in safe mode to have the Security tab present;
as you boot up the computer press a few times the F8 key at the first logo
screen.
On XP Professional the Security tab is brought into view in: Control
Panel\Folder Options\View\uncheck; Use simple file sharing (recommended).
"David M. Schwartz" <dmschwartz210@yahoo.com> escribió en el mensaje
news:yJpXe.221$G64.169@newssvr12.news.prodigy.com...
> Thanks,
> David M. Schwartz
XP PRO: In Windows Explorer, go to Tools, Folder Options, View and uncheck Use Simple File Sharing. Now, when you right click on a drive, folder or file (on an NTFS partition) and select Properties, you'll see a Security tab. Here you can assign or deny permissions based on user name or user group membership.
XP Home: By default, you can only make files and folders under My Documents "private". This is done by right clicking a folder or file and selecting Properties, Sharing. To change the permissions on other folders, you need to boot the computer to Safe Mode and log in on the built in Administrator account. In this mode, you'll see the Security tab in Properties, and you can assign permissions based on user name or group membership.
How Do I Get the Security Tab in Properties - XP Home (makes the Security tab appear outside of Safe Mode)
http://www.dougknox.com, Win XP Tips section
HOW TO: Set, View, Change, or Remove File and Folder Permissions in Windows XP
http://support.microsoft.com/default.aspx?scid=kb;en-us;308418
HOW TO: Set, View, Change, or Remove Special Permissions for Files and Folders
http://support.microsoft.com/default.aspx?scid=kb;EN-US;308419
HOW TO: Disable Simplified Sharing and Password-Protect a Shared Folder in Windows XP
http://support.microsoft.com/default.aspx?scid=kb;EN-US;307874
Doug Knox, MS-MVP Windows Media Center\Windows Powered Smart Display\Security
Win 95/98/Me/XP Tweaks and Fixes
Per user Group Policy Restrictions for XP Home and XP Pro
http://www.dougknox.com/xp/utils/xp_securityconsole.htm
Please reply only to the newsgroup so all may benefit.
Unsolicited e-mail is not answered.
"David M. Schwartz" <dmschwartz210@yahoo.com> wrote in message news:yJpXe.221$G64.169@newssvr12.news.prodigy.com...
> Thanks,
> David M. Schwartz
