Question AMD Build Help - First PC
Fornwith
43
Hello everyone. I was going to buy a prebuilt PC from Cyberpower PC, but was persuaded by almost every video I watched to build my own. I've never built one myself before. My goal is to get 1080p 144hz. I want to overclock and push it safely as far as it can go. So far this is what I have in mind. Prices are just based off of amazon.
Games I want to / play: League, Dauntless, AAA games at minimum 60hz without dipping under.
Case: Still looking, I want a Full ATX for airflow I know that much.
MOBO: B450 - $119
CPU: Ryzen 7 2700 / 2700X - $209/$279 ( Comes with a cooler, but not sure how good it is.)
GPU: RX 590 8GB - $229
PSU: 650 /750 ? - $70 / $100
RAM: 16GB Corsair Vengeance - $75
SSD: 1TB Crucial - $119
OS: Windows 10 ( I saw a linus vid that said you can get it for free? granted its with a watermark but doesn't impact anything. Buying it isn't a problem though.)
2700 vs 2700x from what I researched its about 10% better for about 80$ more. Not sure if its worth for just 10%. I like to multitask while gaming and do a tiny (and I do mean tiny) bit of video editing so its why I chose R7. I want to play Dauntless with a friend, though reccomended is specs is an i7. RX590 competes with the GTX 1660ti which is slightly better, but for the price point is about $50 cheaper. PSU for watts needed with overclocking I checked the forums they said 650 was bare minimum so I'm guessing 700/750? Im trying to budget where I can, but spending a bit more for better performance is doable. As for brands of mobos / gpu I have no idea. I like ASUS rog strix but theyre so expensive. Gigabyte / MSI looks more budget friendly.
Help / feedback appreciated thanks guys.
Final Build is
Case: Corsair Obsidian 750D
Mobo: MSI B450 Gaming Pro Carbon
CPU: Ryzen 7 2700x
GPU: Sapphire Radeon Pulse Rx Vega 56
RAM: 2X8GB Corsair Vengeance 3k MHz C15 RBG
SSD: 1TB Crucial
PCIE: Corsair Force MP500 120GB ( Just for Windows 10 OS)
PSU: 750w Corsair
I bought a 3 pack 120mm Corsair RBG fans. I like to multitask, possibly maybe try streaming in the future and I do a tiny bit of video editing. Also I know people don't like RBG, but as my first ever PC build I just wanna stare at it until I get tired.
If u like the rgb get the trident z ram its soo cool. Also get the h500i case it has led strips and 2 fans built in
Thanks. I don't think the case I have has rbg fans, so I bought them seperate from corsair. I hope everything works when it comes in. My next problem is putting it together and doing the OS and installing whatever drivers or Bios updates if needed.
Wow that case is rly pricy u should prob look at the nzxt case i mentioned its 91 bucks and it has 2 fans led strips and soooo mich room for air flow.
With the h500i u wont need the rgb fans cuz of the rgb led also did i mention the prism cooler that comes qith the r7 2700x is rrgb
The fans that you have running to the front of your case that's cooling your CPU is that a radiator? Also how many slots for fans does the MSI board you have? I dont understand, does every fan need one slot connecting to the mobo?
Yes thats an nzxt kraked x62 water cooler. and the msi board has 4 fan slots which are 4 sets of 4 pins labeled sys fan 1-4. Also there is a cpu fan pin slot and if u get the h500 i it comes with a $50 fan and rgb controller on the back with the fans already cable managed
The fan contoller ads an extra 3 fan slots
