Question AMD CPU: stock fan is blocking RAM slot. I switched to opposite direction but now another problem ?
boostergaming391
39
just like title is saying i bought new ram 3600mhz instead of 3200mhz but okay let's not talk about that now they are equal voltage and worked
problem is amd stock fan blocked ram slot i couldn't put it in until i turned it to opposite direction but it didn't install properly no matter how many times i tried
skin on my finger peeled off from too much turning with screwdriver
how did i know it's not installed properly despite being locked in mobo? the temps are not normal we talking 49 to 67°C on idle and 95°C on 100%
even with 1.1v undervolt it still reaches 83°C AND CORE PERFOMANCE BOOST OFF !!, from what i remember undervolting to just 1.19v did job for it to stay under 75°C
UPDATE : temps on 49% now reach 55°C with no core perfomance boost
SPECS : CPU: RYZEN 5 3600
RAM : 16GB RAM 3600MHZ DDR4
MONITOR: MSI MP251
GRAPHIC CARD: RX 580 2048SP 8GB
MOTHERBOARD: MSI B450M PRO MAX
PSU:CORSAIR CV550
Those temps are with new thermal paste.
Yes- from your first post:
"problem is amd stock fan blocked ram slot i couldn't put it in until i turned it to opposite direction but it didn't install properly no matter how many times i tried"
Something is not right and some photographs showing the current or attempted installation will be very helpful with regards to troubleshooting the problem or problems.
Also: Do you have a link to the AMD stock fan being installed?
This motherboard?
https://download.msi.com/archive/mnu_exe/mb/A320M-APROMAX_B450M-APROMAX100x150.pdf
The objective simply being to determine or eliminate errors of omission or commission with respect to the components and/or installation.
oof my skin hurts from screwdriver
anyway i managed to take fan off heatsink readjust it and then put whole cooler on position it used to be
i was able to mount it but look at these pics am i correct?
temps dropped more
View: https://imgur.com/Z9iw0ko
View: https://imgur.com/SdMyFiA
View: https://imgur.com/RaIuoCJ
View: https://imgur.com/4ojOWjT
View: https://imgur.com/W28gJpa
all 4 screws of cooler and photo of backplate.
As long as it makes contact and you dont have temp problems ,dosen't matter what's the cooler orentation , just make sure the cable it's not to streach
that's the thing i have to undervolt to 1.1v to decrease temps but even then i still reach 85°C under full load which didn't happen to me back then i think
it looks like it dosen't make perfect contact
to be clear , are you using the stock cooler ? it should not affect the new ram slots , read your motherboard manual but im pretty sure you can use a2 b2 slots
i know its effecting the ram slots cause msi couldnt design a board to save themselves the way they designed this board the ram is stupidly close to the socket. they have a habit of putting chokes right next to the socket as well.
temps dropped more
its crap design of the board youll need a tower cooler 90mm / 120mm or top down
depends on what your case is
https://www.amazon.co.uk/Thermalright-SI-100-Cooler-Bearing-technology/dp/B0BL76ZV2T/ref=sr_1_11?crid=362NOXWPR4LKV&dib=eyJ2IjoiMSJ9.olfNWB9RUHcdPaaamAQhkL18kaql5KynJf9jr36lgcnf4OBKvyoVUF76IH1-Tx9JleiG3fVgkTP3M50nRcPmn8PLfY_OuL3YPU1DBHIrrw0X64n6sUaqueQ301XpCgPuR_aBtf5UJgRiq_nx9g0islHOhlNKcX8_6g-JWShDgxkFhH5BKar6AOQa-HehPk7JSZEQK72MGeypAphhsLi-qaiYqRpUAnRb0c_GxrUyFz4.mUIa-pM_sUx8gu2HSmIus32sS0sbbXMfW1f7d-vCUls&dib_tag=se&keywords=cpu+cooler+thermal+right&qid=1719888120&sprefix=cpu+cooler+thermal+right,aps,90&sr=8-11
https://www.amazon.co.uk/Thermalright-Assassin-Cooler-HeatPipes-Technology/dp/B0CMTNZHK7/ref=sr_1_21?crid=362NOXWPR4LKV&dib=eyJ2IjoiMSJ9.dmK1ucFQqvuIfWA_n2e1WHmsHkXJ6uZM3sxIXJlY1JT1XgHbwS46eXpGn_qcgEgB_SL4Uk8T8Q_WfPslO6Zn7OXjcElTQ1CE6CJOydO8poywbs5xsp_i1bKQ6XQksMVNJGuUut1r0BdKJy4m5gcyHz0QKNPIFG2u92RaI9IyO9Rdtiz4NIEbgUyO3G04nKav.PyUUCA6QOWNuBvWIx08o6-WlrydhV_fMmO6DMS8H1a0&dib_tag=se&keywords=cpu+cooler+thermal+right&qid=1719888008&sprefix=cpu+cooler+thermal+right,aps,90&sr=8-21&th=1
https://www.amazon.co.uk/dp/B0CJDNS...trial&sp_csd=d2lkZ2V0TmFtZT1zcF9kZXRhaWw&th=1
