G
Guest
Guest
I wonder what the idle power would have been with a reasonably rated PSU? The efficiency of the typical PSU drops off at very low power, so they aren't even certified below 20% of rated power. The highest load in this test is below the 20% cutoff for the PSU used, and the idle power is only ~6.5% of rated PSU power. You can tell that the difference between the two chips is small, but the reported idle power is likely to be way higher than it would be with a good 250 W to 380 W PSU.
