Outlander_04 :
jimmysmitty :
Outlander_04 :
Actually the revenue ramp cant start until after products are shipped . Revenue ramp in 2016 can only mean one thing
But since you have just said that there is no specific time frame given HOW COULD THERE POSSIBLY BE CONSIDERED TO BE DELAYED ?
LOL
Would you agree that an equally valid title backed by just as many facts could have been :
"New AMD processors smash intel performance"
There is just as much evidence for that as anything else at this point
And once again there is no technical or yield problem with the 14nm lpp process . None what so ever .
A delay to 2017 would be a delay but again the article stated it was
possible not a 100%.
And again you keep saying things with no sources to back anything you are saying up. How would you know the yield rates of GloFlos 14nm LPP? Do you work for them?
And do you think if there was they would say anything publicly about it? That would hurt business and sales. Look what happened to TSMC and 20nm. Both AMD and nVidia skipped it due to yield and technical problems.
The LPE and LPP processes are structurally identical . Probably what has changed is one of the metal gates .This may be due to nothing more than licensing arrangements to a patent holder. Its not harder to make one than the other . The LPE version may exist purely as a cost saving because it works fine for its intended use without paying that royalty .
There is no issue with production because they are already manufacturing these devices .
On top of that AMD have always maximized sales yields by binning and selling as 2,3,4 cores with athlon and then 4,6,8 with FX [ because of the paired cores ] . The relative prices of 6 and 8 core variants is all that will be affected by yields if history repeats .
Historically there is a website that has pretty much nailed every move AMD has made .
[ and its not tomshardware that even editorialized that AMD had given up top end processors . LOL ]
Most likely the best public information regarding AMD in 2016 can be found here
http://wccftech.com/amd-zen/
http://wccftech.com/amd-zen-launch-q4-2016/
http://wccftech.com/amd-zen-k12-taped/
The information is very consistent with the link in this article at toms .
No the LPE version exists because Samsung wanted to get their 14nm out earlier and the LPP was their original design. The LP literally stands for "Low Power" while the E means "Early" and the P means "Performance". I am not arguing that the LPE and LPP are similar. I am stating that GloFlow is not using the base LPP for Zen CPUs but they are having to modify it to be able to work better with a high power design. And it is not as simple as changing a gate, there is a lot to a process node. Believe me or not, the community college I went to had a scholarship through Intel and worked with Intel very closely. A friend of mine did the scholarship and now works for Intel in Chandler (we were in a city 2 hours away). I have personally seen what it takes to create and fabricate a chip and it is not some simple task like turning a gate on/off.
If it were than easy then Intel would have moved to 16nm sooner than 14nm. However that specific node is design for NAND and SRAM, not for CPUs and high power processing cores. You are trying to simplify what takes years of work to do.
Binning is not new. You used to be able to do a pencil mod to the Radeon 9500 to make it a 9700 Pro or to the Q6600 to make its FSB default to 333MHz instead of having to tweak the BIOS. Every company does it. Profits are not the only thing affected by yield, if yields are too low and they can't fill OEM channels they will suffer more than if they delay and can fill channels.
Are you honestly linking WCCFTech? They are nothing but a rumor mill. They spit out rumors left and right even if the rumors are known to be bogus.
http://wccftech.com/amd-r9-390x-8-gb-hbm/ - Wrong, 4GB limitation to HBM
http://wccftech.com/fiji-xt-4gb-amd-dual-8gb-hbm-msrp-849/ - Wrong, again 4GB limitation and MSRP was $650
It is really hard to trust a website that reports daily on rumors just to get hits.
So you have an actual source or is the rumor mill your only source?
