Another first build, need suggestions
w00k1e
Hey guys, I'm looking to build a computer that will mainly be used for graphic design and video editing, not much gaming. I would like to use the i7, 6gb of RAM, and be able to use my current triple monitor setup (this means I can't run SLI correct?). My budget is right around $1200, I saw this setup in another post, but I don't think the video cards will work with my triple monitors. What do you guys think?
COOLER MASTER RC-690 Case $59.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119137
CORSAIR CMPSU-750TX 750W Power Supply $104.99 after rebate
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
Intel Core i7 920 CPU/ Gigabyte GA-EX58 Combo $453.98 after rebate
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.181982
(2x)-MSI N260GTX-T2D896-OCv2 GeForce GTX 260 Core 216 $349.98 (only 1 rebate)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127409
G.SKILL 6GB (3 x 2GB) 240-Pin DDR3 $89.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231247
XIGMATEK Dark Knight-S1283V $39.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233029
LG Black 22X $25.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136153
Western Digital Caviar Black WD6401AALS 640GB $74.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136319
MX-2 Thermal Compound $6.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16835186020
Total $1206.89
edit: fixed links
All of your links are broken.
From what I can see, your build list is very good (it looks like I might have had something to do with its creation 😛). Make sure you pick up Vista 64bit.
Since you aren't concerned about gaming, then I would get lower-end GPU's to support all your monitors. If you still want to be able to play some games, then look at a 4850x2, which can support 4 monitors on its own and is "xfire-in-a-card". You can also get one good nvidia GPU like a GTX 275 to support 2 monitors and have the possiblilty of gaming, and then just get like a 9500 GT for the other monitor as well. This might be a better option for you as Nvidia GPU's typically work better with the kind of work it sounds like you will be doing.
Very nice build. :)
