i plan to build my new PC in the p182, based on a q6700 or q6450 and a 8800gts or 9800 gtx,
It comes with three fans (triCool).
I would like to replace them by more silent ones (S-Flex or Noctua).
what kind of speed will I need? 800 rpm are enough for the case fans? I plan to do some OC, but shure not to the max.
furthemore I plan to buy teh ASUS maximus formula and place the Xigmatek HTD-s 1283. This combo should be PWM-able, isn't it?
thanks to all
thanks to all
