I now have a new (to me) system in this case and an looking at what the prior owner did and didnt do. Inside is a GA z77 ds3h MB. The system came with no HD/OS and no add on cards so i was cleaning and cable routing in prep...the Antec case manual(PDF) says it has both an AC97 and HDA cable/connectors.
I found the unconnected HDA cable floating in there and nothing connected to the front audio connector on the MB. I then started looking for the AC97 connector/cable and don't find one. should i be concerned or just go ahead and connect the HDA to the front panel.
As i look deeper into this case, i am missing a couple of the rails for putting in another 5.5 external drive and i have none of the trays for installing hard drives, so searching for that stuff too.
